Allignment Accident. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2007, 08:14 PM   #1 (permalink)
View TachPHD's Photo Gallery
my front right was hit in and the allignment is way off now. the wheel itself is cambered in negative, wheel is tilted... about 2 Degrees. I checked the control arm, it seems fine. replaced it and everything, no difference. What i then notice was that the joint that slips into the body socket, where that one long bolt goes through, that seemed kind of bent inward towards the driver side. What are some of you guys suggestion for this situation.
thank you for any response.
TachPHD is offline   Reply With Quote
Old 02-03-2007, 03:18 AM   #2 (permalink)
View toyomoho's Photo Gallery
If frame damage a body shop would most likely pull it back into location using hydraulic rams and chains. You might be able to do this with a change host, but will most likely need to secure the car from moving. Think about how the frame was damaged, and then try to undamage it in the same direction, angle, etc.
He destroyed my belovid 86 -HiTMaN- Archived Corolla threads 25 05-25-2007 02:40 PM
F/S 2000 Toyota Camry *damaged* *repairable* Only 63k!!! 92SayOh Vehicles 8 12-16-2006 05:56 AM
2005 Camry Accident desi_prodigy 5th & 6th Generation (2002-2006 & 2007-2011) 18 08-31-2006 03:18 AM
Gen3.5 Accident Update importfest 3rd & 4th Generation (1992–1996 & 1997–2001) 1 11-09-2003 10:23 PM
Auto Accident Insurance Fruad And Scams Sportivo Concepts Off Topic 0 10-22-2003 06:57 PM
