How easy to fix broken door handle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2007, 08:34 PM   #1 (permalink)
View toyrabbit's Photo Gallery
The outside door handle on the drivers side broke today. I have been quoted anything from $250 to $750. How difficult would this be to fix?
toyrabbit is offline   Reply With Quote
Old 12-12-2007, 09:31 PM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
It is cake. Took me about 20 minutes on my 1996 Paseo. Buy one from ebay and take off your door panel. I hope you have panel tools and a pick set. Small hands help too!
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 12-12-2007, 10:11 PM   #3 (permalink)
I don't have panel tools or a pick set, but I guess I can find that. Thanks!
Old 12-12-2007, 10:38 PM   #4 (permalink)
Got a FC3S!
Paseo15psi's Avatar
Get a small 1/4" metric socket set with a swivel (or the wrench that can angle) or a set of short racheting gear wrenches. The nuts holding on the handle are 10mm if I recall correctly. Even if you have to buy new tools, it will be cheaper than the quotes, you will learn something, and you will have more tools. All good things!
btw, Welcome to the site. What car do you have exactly, so that we may better tell you what to do?
Old 12-13-2007, 08:22 AM   #5 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
Replaced mine a couple of moths ago. Retainig nuts are 10mm. Hope you know some double jointed midgets to reach some of it. LOL
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
Old 12-13-2007, 11:31 AM   #6 (permalink)
TO.COM Refugee
alfradio's Avatar
View alfradio's Photo Gallery
When it comes to working on my own car, I'm probably the biggest chicken in the world but, I too replaced my driver side door handle a few months ago and it just takes a bit of PATIENCE!!!!!
The first thing (and probably most tedious) is removing the window crank...
Next, unscrew the single screw which holds the inner door handle in place and then pull the inner door panel off carefully... the job can be done without the panel tools but, I'm sure they would have made things easier...
Once the panel is worked loose, you'll encounter a piece of plastic sheet, held in place by some tar-like adhesive.... I just got rid of that entirely... once all that has been accomplished, it's a simple matter of unscrewing the old broken door handle and replacing it with the new one...
$750 is an OUTRAGEOUS price to even, for a second, consider... Hell, you could almost buy another car for that price... $250 is not much better...
Take your time, don't get frustrated and you'll have it done in less then an hour...
Al SANTOS CLAUS
alfradio is offline   Reply With Quote
Old 12-13-2007, 02:16 PM   #7 (permalink)
View Starkidd813's Photo Gallery
Its easy I have have huge hands, and I managed to do it. no special tools just used to working on cars.
96 toyota tercel ( Daily Driver)
Starkidd813 is offline   Reply With Quote
Old 12-14-2007, 05:48 PM   #8 (permalink)
View thoughthard's Photo Gallery
Be aware that some people have been having breaking issues with eBay handles that are not OEM...
thoughthard is offline   Reply With Quote
Old 12-16-2007, 07:47 PM   #9 (permalink)
airswoosh1's Avatar
View airswoosh1's Photo Gallery
that's true. After my brother and I replaced his driver's side handle with one off of ebay, it broke less than a year later and I had to replace it again. Luckily, I had an OEM spare this time around.
http://www.cardomain.com/ride/1319747
airswoosh1 is offline   Reply With Quote
Old 12-17-2007, 12:16 AM   #10 (permalink)
paseo12's Avatar
View paseo12's Photo Gallery
Also be careful with Ebay... I bought a handle last year driver side, and the lock on the new handle called for a Passenger side one instead... I was pissed, but realized too late to send it back. The hardest part in the whole job is the damn clip that holds the lock in! Have fun its easy and looks like you have a lot of help!
Scott
paseo12 is offline   Reply With Quote
Old 12-17-2007, 08:40 AM   #11 (permalink)
toyrabbit, what year and model of Toyota do you have? Where in CO are you located?
Old 12-18-2007, 02:19 PM   #12 (permalink)
Paseo12, The exact same thing happened to me.
Old 01-29-2008, 07:24 PM   #13 (permalink)
paseo12's Avatar
It sucks!
It sucks, because I bought two brand new locks at the same time... I could only use one though! The thing that sucks the most is that the lock Barley moves to unlock! Oh well it works for now!
Fix for knocking sound? Fitz235 2nd Generation (2005+) 22 01-05-2006 04:45 PM
Broken down and need help! dexterous2000 89-95 Toyota Pickup/Hilux 6 10-03-2005 10:26 PM
Broken rear stabilizer bar -- what is the best fix? Moufette Cressida Forum 3 08-21-2005 10:37 PM
so my car got broken into... andyman61 Off Topic 12 04-27-2005 01:20 PM
91 Corolla Fix it/Interior Questions nycxandy Archived Corolla threads 0 08-21-2004 12:50 AM
