NEED Help/ Advice 94 tercel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2007, 06:47 PM   #1 (permalink)
zoomis's Avatar
View zoomis's Photo Gallery
USA NEED Help/ Advice 94 tercel
I have a 94 tercel and I ve been reading everyones posts, so I decided to put a 5efe engine in my tercel after the 3e blew. So I put it in and not too long after I got it mounted and everything tightened down I turned to the wiring what I thought would be the last step, besides vacuum hoses, and Everything was different, turns out as far as I can tell it looks like the engine from a 95-99 paseo instead of a 91-94 paseo, the company I ordered it from sent me the wrong one wont let me exchange it... I changed out the coil pack and put a distributor from a 93 Paseo I got out of the j/y. Anyway I cant get it started all the WAY What to do?? PLZ help love this car THX
zoomis is offline   Reply With Quote
Old 12-18-2007, 07:31 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
so what youre saying is you got a 5efe that youre trying to run off the 3e ecu? or did you wire in the 5efe ecu?
4agetercel is offline   Reply With Quote
Old 12-18-2007, 07:35 PM   #3 (permalink)
zoomis's Avatar
Yeah I left the 3e ecu on.
Old 12-18-2007, 07:41 PM   #4 (permalink)
Wonderbread
4agetercel's Avatar
most likely there in lays your problem... the 3e will run on a 5efe ecu but wont work the other way around because the 5efe has an extra sensor in the distributor... providing it was from the same generation paseo(91-94)... seeing as you have the engine with the electronic ignition (95-99)you'd need the ecu for that engine and would have to wire it in for it to work.
Old 12-18-2007, 07:53 PM   #5 (permalink)
zoomis's Avatar
So I need to wire in the the ECU from a 95-99 paseo engine, or 95-99 tercel? Can I use the same wirre harness or do I need to re do the wire harness as well??
Old 12-18-2007, 07:59 PM   #6 (permalink)
Wonderbread
4agetercel's Avatar
well get the ecu for whatever the engine is out of...if its paseo then paseo... as for the wiring you most likely will have to re-wire it because i doubt the connections are the same for the 3e as the 5efe
Old 12-18-2007, 08:10 PM   #7 (permalink)
zoomis's Avatar
Alright I guess I will try that but what about the vacuum lines there are 2 or 3 extra lines Im not sure where they are supposed to go I have been trying to find some pix so i can get some kind of idea but cant find any for the 95-99 engine... Any thoughts
Old 12-18-2007, 08:17 PM   #8 (permalink)
Wonderbread
4agetercel's Avatar
which ones are they?? one of them may hook on to the airbox if you havent hooked them up yet... the brake booster maybe?
Old 12-18-2007, 08:23 PM   #9 (permalink)
zoomis's Avatar
they are on the right side of the engine, near the belts, on top of engine mount, they used to plug in block and in take I think, I think one of them goes to the Ac pump but my car is not equiped so SHould I just plug it??
Old 12-18-2007, 08:31 PM   #10 (permalink)
Wonderbread
4agetercel's Avatar
Ohhh the VSV's (vacuum switching valves).I believe they have something to do with fuel pressure if iam not mistaken... do they hook onto the fuel rail?
Old 12-18-2007, 08:36 PM   #11 (permalink)
zoomis's Avatar
yeah thats right one of them did but on this engine there isnt anywhere to put it i think i just got it towed to my new house after 6 months so im working off of memory its too dark to check it right now in Oregon. but yeah the vsv thats what they are called what should I do with them there is 1 extra spot on the brown vsv the same color as the old one, but there is one more with 2 spots I dont know what to do with
By the way I checked out your ride I like the interior what did you use to paint it?? Neons Sweet . thx I appreciate all your help and insight
Old 12-18-2007, 08:40 PM   #12 (permalink)
zoomis's Avatar
K actually the red vsv has 2 the grey has 3 looks like one goes intothe intake and one into the fuel pressure regulator attached to the fuel rail.
Old 12-18-2007, 08:54 PM   #13 (permalink)
Wonderbread
4agetercel's Avatar
you have a e-mail? ill send you pics of the 3e vsv's, and i have a vacuum hose diagram for the 5efe.. yeah the interior i ripped it out one summer and painted it with normal exterior car paint... taillights are different now though. still a work in progress always will be
Old 12-18-2007, 08:59 PM   #14 (permalink)
zoomis's Avatar
Yeah Zoomis17@gmail.com , Thats awesome I appreciate it you changed the tail lights w? what did u do?
Old 12-18-2007, 09:06 PM   #15 (permalink)
Wonderbread
4agetercel's Avatar
AE86 Tail lights
Basically all i did was wet sand the black off and sprayed a clearcoat on the lights... i took that pic about 2 weeks ago
'94 tranny swap, need advice karander Archived Corolla threads 5 02-20-2007 05:06 PM
Electrical Problem '94 Tercel cjahn Introduce Yourself Here 0 12-12-2006 06:55 AM
94 4afe into 91 Corolla fabbb Archived Corolla threads 4 12-11-2006 08:19 PM
94 tercel bgmeme Tercel, Paseo, Starlet, and Sera Forum 2 08-15-2005 03:57 PM
Hmmm oil light flicker on 94 tercel.. Bobby C 01TA Tercel, Paseo, Starlet, and Sera Forum 7 10-25-2003 10:01 PM
