Crankshaft Pulley 94 Paseo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2007, 03:47 PM   #1 (permalink)
View donbara's Photo Gallery
I have a 94 Paseo with power steering and A/C. I was removing the harmonic balancer (crank shaft pulley) and found that the pulley for the alternator drive was seperate. Is this normal? Also there were some rub marks on the timing belt cover from the harmonic balancer. Does anyone know if the timing belt cover and harmonic balancer are avalible at parts store or are they only avalible from Toyota? Much Thanks for any replies, Don
donbara is offline   Reply With Quote
Old 12-21-2007, 10:31 AM   #2 (permalink)
View Daox's Photo Gallery
Yeah, its a two part pulley. Unless you have holes in the cover due to the rubbing I wouldn't even bother replacing it. Most likely both are going to be a Toyota parts.
Daox is offline   Reply With Quote
Old 12-26-2007, 01:30 AM   #3 (permalink)
View Helps's Photo Gallery
harmonics 66 bucks at autozone. checker has it for 70. unless its actually dragging against the cover or making the engine bounce dont bother with it.
Helps is offline   Reply With Quote
Old 12-30-2007, 09:57 AM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
My timing cover has rub marks too. The 3E engine I took out had them also. It seems to be an "E" engine flaw.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 12-30-2007, 12:36 PM   #5 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
yup mine to the pulleys seem very cheap
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 12-30-2007, 03:36 PM   #6 (permalink)
I checked at Autozone in PA where I live and they said they didn't have one listed. Are the harmonic balancers the same on all 1.5 litre engines? It's starting to make a helluva racket now so I think I should change it but can't seem to locate one. I am going to check junk yards tommorow, but I doubt they will want to take it off a "good" engine. Any suggestions on where to get one. Thanks Don
Old 12-30-2007, 08:42 PM   #7 (permalink)
Donald's Avatar
I don't think the problem is the pulley. I think the cover looses it's shape with age and heat, and bows out to touch the pulley.
Old 12-31-2007, 07:42 AM   #8 (permalink)
My problem is the harmonic balancer, The drive pulley for the alternator has come loose from the other pulley on the harmonic balancer, it's rattleing all around, and the alternator belt just broke, Again does anyone know of a source for these pulleys? Thanks Don
Old 12-31-2007, 02:17 PM   #9 (permalink)
Donald's Avatar
Sorry. I got off on a tangent about the timing cover.
How much does Toyota want for the pulleys?
By the way, how many miles on your car? I want to know when to start planning for a pulley replacement on mine.
Old 12-31-2007, 03:17 PM   #10 (permalink)
Haven't contacted Toyota yet, I found one at a local junkyard, am going to get it on Wednesday. 205,000 miles on it, rumor has it that the harmonic balancer is avalible at Autozone, but here in PA it isn't avalible. I will let you know how it turns out.
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Need advice for crankshaft pulley bolt removal BIG A Camry & Solara Lounge 13 08-13-2011 09:31 AM
HELP~!!!!Removal of Crankshaft pulley bolt undertow29 89-95 Toyota Pickup/Hilux 17 01-28-2007 05:06 AM
Some help getting a 94 Paseo Pirate1650 Tercel, Paseo, Starlet, and Sera Forum 6 10-21-2005 01:30 PM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 09:20 PM
