how to remove automatic shifter? 92 Paseo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2007, 02:08 AM   #1 (permalink)
View dandism's Photo Gallery
(92 Paseo) the sliding part that hides the guts of the automatic shifter is missing so I want to install a new one but I can't seem to figure out how to take the shifter off. Any tips?
Thanks,
Dan
dandism is offline   Reply With Quote
Old 12-30-2007, 10:09 PM   #2 (permalink)
View Mike Kamm's Photo Gallery
First you need to remove the console. Then you'll see the three phillps head screws holding down the cover that contains the sliding part. Then to remove the cover itself, you'll have to remove the single phillips head screw that holds the shift handle on. Then slide the shift handle upwards. You'll find that the wires to the overdrive switch must be disconnected. Not sure if you'll have to cut them or if they can be disconnected another way. I didn't take mine that far apart.
Mike Kamm is offline   Reply With Quote
trany swap: Does the Paseo 4sp overdrive automatic fit onto Tercel 3EE ? tercel_maniac Tercel, Paseo, Starlet, and Sera Forum 6 10-13-2006 11:09 AM
Looking at a 92 Paseo.. Infinitrium Tercel, Paseo, Starlet, and Sera Forum 11 07-11-2006 11:34 PM
dashboard & front seats Midnight87 Supra Forum 6 07-09-2006 05:09 PM
automatic shifter MYCARcamry Camry & Solara Lounge 1 07-22-2004 08:27 PM
Installing an Automatic shifter.. V6LE Camry & Solara Lounge 13 04-21-2003 02:13 PM
