Idleing problems with 93 Paseo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2007, 05:44 AM   #1 (permalink)
View sportsaholic07's Photo Gallery
My 93 Paseo lately has been having problems idleing......after warming up for about 3 mins it starts to rev itself to about 18000rpms and then it stops revving back down to about 1200rpms it fluxuates like this for about another 5 mins and then is good.
Any ideas why?
Thanks in advance
Sportsaholic07
sportsaholic07 is offline   Reply With Quote
Old 12-21-2007, 10:30 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
AE86 tercel
car may be low on coolant my tercel did that because there wasnt enough in it last winter
4agetercel is offline   Reply With Quote
Old 12-22-2007, 07:44 PM   #3 (permalink)
Nope
Thanks for the idea,
I went out and checked, but no luck, coolant has plenty in it.
Any other ideas?
Old 12-22-2007, 08:13 PM   #4 (permalink)
Wonderbread
4agetercel's Avatar
AE86
only other thing i can think of is a sensor in the throttle body or a vacuum hose that has fallen off
Old 12-24-2007, 03:43 PM   #5 (permalink)
View Dhavut's Photo Gallery
probably a vaccum leak somewhere most likely........ my tercel with a paseo engine had a vaccum leak but it constantly revved high and low and din't go away until i blocked the vaccum leak.......... then it ran fine......... maybe vaccum hose came off somewhere... look around i guess
Dhavut is offline   Reply With Quote
Old 12-24-2007, 05:07 PM   #6 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
I would check the thermostat and the water temp sensors.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 12-30-2007, 10:00 PM   #7 (permalink)
View Mike Kamm's Photo Gallery
If you found the problem, please let us know what is was. My '93 is doing the same thing, but I caused it somehow. I did an automatic to manual swap and now I have the same idle fluctuation during warm up. I bled the cooling system properly and checked all of the vacuum hoses twice.
Mike Kamm is offline   Reply With Quote
Old 04-29-2008, 12:33 PM   #8 (permalink)
I figured it out a little while ago....It was low on coolant, the radiator cap is not working properly so when it over flows when the engine heats up it does not draw the liduid back in when it cools down.......i put some more coolant in and it works fine now
'93 Paseo repair questions paseo1 Tercel, Paseo, Starlet, and Sera Forum 0 05-15-2007 04:42 PM
Paseo Problems lucacarn Tercel, Paseo, Starlet, and Sera Forum 5 07-29-2006 04:02 PM
93 paseo mystery!!! paseonate Tercel, Paseo, Starlet, and Sera Forum 3 05-25-2006 12:59 PM
93' paseo engine question 02_vvt-i Tercel, Paseo, Starlet, and Sera Forum 13 11-04-2005 01:52 PM
