Front axle nut stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2007, 02:50 PM   #1 (permalink)
View Banshee365's Photo Gallery
I'm taking the car all apart to do the clutch and am having a huge problem with the passangers side axle nut. I've tried my 3/8" impact on full pressure and max setting, I've tried heating it up with a propane torch since I don't have a oxy/acc torch. I've jumped up and down on a 2' breaker bar and it will not budge. What would yall suggest?
-Kelly
Banshee365 is offline   Reply With Quote
Old 12-28-2007, 03:52 PM   #2 (permalink)
View tgidavid's Photo Gallery
Spray with either PB Blaster or liquid wrench. walkaway for 30 minutes. Come back and spray again. Wait for a while then jump on it with a breaker bar.
tgidavid is offline   Reply With Quote
Old 12-28-2007, 03:57 PM   #3 (permalink)
View Helps's Photo Gallery
use a long friggen pipe over the breaker bar. dont know why everything in a toyota is torqued to a bagillion lbs
Helps is offline   Reply With Quote
Old 12-30-2007, 09:37 AM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Get the longest 1/2" breaker bar you can get (longer than a craftsman) and an impact socket (1/2" drive, ofcourse), stick a big screwdriver in the brake rotor so it butts up against the caliper, and stand on the breaker bar.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 12-30-2007, 06:32 PM   #5 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
go left not right lolol
4speedsleeper is offline   Reply With Quote
Old 12-30-2007, 11:25 PM   #6 (permalink)
View Heavy_D's Photo Gallery
umm make sure you do what he said ^^, and make sure that some where on the nut doesnt has that dent, now for the gun, get a 1/2 impact drive, 3/8 is nothing for it, and yea pb blaster is good and some wd-40 if anything get new axels aswell.
Heavy_D is offline   Reply With Quote
Old 12-31-2007, 12:07 AM   #7 (permalink)
View stricular's Photo Gallery
I use a long piece of pvc pipe, over the top of a shop jack handle, over a breaker bar. I also like to use a jack stand to stabilize the socket underneath. For the love of everything good, use a six-point socket!
stricular is offline   Reply With Quote
93 Toyota Pickup cv axle replacement suggestions PurplePower 89-95 Toyota Pickup/Hilux 3 02-21-2010 05:58 PM
axle play tranny side '91 Corolla 4AFE RotBoxCorolla Older Generations (1969-1987) 6 09-28-2007 02:32 PM
Front axle C clip - driver side Robar 3rd & 4th Generation (1992–1996 & 1997–2001) 2 06-25-2007 12:50 PM
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
