cheers Shawn!
I think you are right.
I did a little test that is supposed to tell if the problem lies with the battery or with the alternator: I started the car (without a problem) and unplugged the negative side of the battery. Someone told me that when you do that and the car dies, then you know it is the alternator-side that is causing the problem, as normally, the alternator should keep the car running when you do that..
The battery itself gives out a 12.63 Voltage when the car is not running, and a 12.23 Voltage when it is running (without lights on and such..).
Now, from what I read in other postings on this forum, it could either be the ALTERNATOR, the WIRING, or the VOLTAGE REGULATOR that is causing the problem, if it is not the battery.
I'm not sure how to go about finding out what is the exact cause. I took out the alternator, opened it up (to a certain degree), but did not see anything strange. Well..things are a bit rusty, to be honest..
Also, july 2007 I had already replaced the carbon contacts thingies in the dynamo (don't know the English word for it..), so that is not the problem either (they still looked good anyway..not to worn down and they were not stuck either).
However, I have no idea what a voltage regulator looks like and where I can find it in the starlet..
I want to check the wiring, but I'm not sure how to go about that either. I do have a voltage checker.
What I find strange is that it happened alloversudden.. I had been driving the car a couple of hours before, without any problems.. I then start it again, and the problem is there.. I though alternator dying signs are petering out, instead of a sudden die off..
Anyway, any or all help is appreciated!
regards,
M.T.Pilot
