Piston rings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2008, 01:54 PM   #1 (permalink)
View Starkidd813's Photo Gallery
Piston rings
Okay my 4th cylinder plug is getting a lot of oil on it. I believe I need to replace my rings. My question is what are the steps that I need to take,
and how do I set the pistons after the job is done. Im pretty mecahnically inclined I just have never done this before so dont be afraid to get technical.
96 toyota tercel ( Daily Driver)
Starkidd813 is offline   Reply With Quote
Old 01-04-2008, 02:37 PM   #2 (permalink)
View Daox's Photo Gallery
You'll want to just get a Haynes or Toyota service manual. It'll tell you what you need to know.
Daox is offline   Reply With Quote
Old 01-04-2008, 07:36 PM   #3 (permalink)
View Helps's Photo Gallery
when i did the rings on my 91 tercel i did it through the bottom. do a compression test and see where it leaks from.
Helps is offline   Reply With Quote
Old 01-07-2008, 04:43 PM   #4 (permalink)
View davecl's Photo Gallery
does the engine smoke when you are driving or just on start up? Or is it somking at all. If it is all the time then I would say rebuild and if just at start up replace valve seals.
davecl
as far as a rebuild goes take the head off and if it like my 94 tercel you will have to drop the exhaust to take the oil pan off then just take off the caps and pop pistons out the top. make sure to clean good and get rid of any carbon build up at the top of each cylinder.
davecl is offline   Reply With Quote
My MR2 3sgte piston rings went out. victor91mr2 MR2 Forum 3 07-01-2006 05:12 PM
3ee Piston Rings shogun6684 Tercel, Paseo, Starlet, and Sera Forum 5 10-02-2005 04:21 PM
Piston Rings 95XleV6 Hardcore Tech and Competition 1 11-26-2002 08:16 AM
Piston Rings 95XleV6 Camry & Solara Lounge 0 11-24-2002 03:39 PM
