1991 tercel motor/transmission - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2003, 12:48 PM   #1 (permalink)
View matt_p182's Photo Gallery
I am thinking of swaping a 5spd manual into my car which is an automatic now. I figure i should do some engine mods while Im at it. i have a 3E engine in it now. is it possible to get a turbo from a junkyard from like an MR2 or something and put it on my motor or is there a cheap turbo motor I can buy and put in without much trouble. Also for the transmission should i stick with a 1991 tercel transmission or should I get one out of a different car for a better gear ratio?
matt_p182 is offline   Reply With Quote
Old 10-04-2003, 11:47 PM   #2 (permalink)
My Dixie Wrecked
wedge's Avatar
View wedge's Photo Gallery
Any 5-speed Tercel or Paseo tranny will fit perfectly, and they all have the same ratios. A Corolla tranny will give you better ratios but requires alot more work, it would involve swapping the gears from the Corolla tranny into the bellhousing from a Tercel tranny. Not really worth it unless you've already got a manual to start with. Otherwise there's alot more stuff you'd need to buy first.
Racing is everything
wedge is offline   Reply With Quote
Old 10-10-2003, 05:12 AM   #3 (permalink)
View 91redtercel's Photo Gallery
the mr2 turbo is dohc right? if so the turbo exhaust manifold will not fit and that just about kills the turbo project right there
91redtercel is offline   Reply With Quote
Old 10-22-2003, 04:45 PM   #4 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
Easiest turbo engine swap is the 4EFTE. Everything bolts up, you'll need some misc parts, ECU, etc, and you'll need to customize the wiring harness from the 4E with parts from your existing one, but a lot of people have done it and it's definatley the most straightforward.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 12-09-2003, 12:07 AM   #5 (permalink)
View 91jdm_t3e-e's Photo Gallery
hey i have the same 1991 tercel yet 4spd. would it be easier for me to swap my tranny to corolla 5spd? and what year corolla you talken bout? one more thing it wouldn't just bolt on right? need a lil custom fabrication to the fitting?
91jdm_t3e-e is offline   Reply With Quote
Old 12-09-2003, 12:09 AM   #6 (permalink)
Corsa!
Galvatron's Avatar
Dont bother with a Corolla tranny, too much work. Just grab a 5 speed from a 91-94 Tercel DX or a 92-95 Paseo. Will bolt right up.
2007 Suzuki SV650S
Old 12-09-2003, 12:11 AM   #7 (permalink)
but the ratios wont be as good right?
Old 12-09-2003, 12:13 AM   #8 (permalink)
Corsa!
Galvatron's Avatar
True, but unless you have tons of extra money and time, I would just go with the Tercel/Paseo tranny.
2007 Suzuki SV650S
Old 12-09-2003, 12:15 AM   #9 (permalink)
paseo tranny holds rpms @6500rpms or no? bcuz im tired of this 5200 rpm lil grl stuff lol. if it were is there a way i juss swap out ecu from 5efe?
Old 12-09-2003, 12:18 AM   #10 (permalink)
Corsa!
Galvatron's Avatar
I believe that both tranny's are the same, the limiting factor is the engine. The 3E-E redlines at 5800 while the 5E-FE redlines at 6800.
2007 Suzuki SV650S
Old 12-09-2003, 12:23 AM   #11 (permalink)
thats not bangen lol i just wanna see how far i can take this lil 3e-e. you think i'll feel any difference between the 4spd n 5spd except for the fact i have one more gear? lol
Old 02-05-2004, 09:46 PM   #12 (permalink)
View deizel295's Photo Gallery
lemme know what you gonna do with the old 3e-e, i need one.
If you love it, that's enough for me.
Drive fast, take chances.
deizel295 is offline   Reply With Quote
Old 02-06-2004, 07:32 PM   #13 (permalink)
N/A bites
Tercel GTS's Avatar
The 5spd comes with a lower ratio final drive. 5th gear is overdrive to give the same ratio as a 4spd in high gear. So therefore through the first four gears you get improved accelleration from the 5spd.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
