Tercel Gauge Cluster Making Noise ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2008, 03:15 PM   #1 (permalink)
View Jenni's Photo Gallery
Hi i am new to this forum and i usually find a way to fix my car but this time im stuck. i have a 93 Tercel 3spd Auto. So my speedo is all messed up anytime i step on the throttle it starts making this noise like if the needle wanted to spin backwards and its very annoying. Also anytime i go over 30mph the speedo goes nuts and starts jumping all over the place and saying that im going 110mph ! im going to record a small vid so you guys can maybe help me diagnose the problem. I need help !
Thanks in advance. Jenni
Jenni is offline   Reply With Quote
Old 01-22-2008, 06:27 PM   #2 (permalink)
View Daox's Photo Gallery
Sounds like you need a new speedometer cable, or a new speedometer.
Daox is offline   Reply With Quote
Old 01-22-2008, 08:33 PM   #3 (permalink)
well i was going to go to the junkyard on sat to find a new speedo. is it hard to replace a speedo cable ?
Old 01-23-2008, 09:13 PM   #4 (permalink)
ivrunner's Avatar
View ivrunner's Photo Gallery
no, not to hard at all. twist it out of the tranny then pop it out of the instrument cluster. it might be possible that yours is just loose. check that out first.
86 Yota pickup - (trail rig) SAS, tube doors, hi steer, header, bobbed w/ 35's
82 toyota hilux - (restore project) bobbed w/ 33's
84 toyota pickup (work truck)
88 toyota tercel (daily driver)
ivrunner is offline   Reply With Quote
Old 01-23-2008, 10:44 PM   #5 (permalink)
from the tranny does it lead into the firewall then to th back of the cluster ?
Old 01-24-2008, 08:37 PM   #6 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
4th Generation
yeah it goes from the trany(youll see it beside the shifter cables) or if its auto in the back of the tranny, and through the fire wall into the cluster
4agetercel is offline   Reply With Quote
Old 01-25-2008, 08:30 AM   #7 (permalink)
View Kevpalf's Photo Gallery
My 95 Tercel Does The Same Thing, But Only When Its -15c
Kevpalf is offline   Reply With Quote
Old 01-25-2009, 11:29 AM   #8 (permalink)
View Addedias's Photo Gallery
My 95 also does this at low temps and as the car warms up it goes away.
I have a manual transmission.
Could someone post a picture of where the cable is?
My goal is to try and lubricate it before replacing.
Addedias is offline   Reply With Quote
Old 01-25-2009, 12:53 PM   #9 (permalink)
Wonderbread
4agetercel's Avatar
its the cluster that makes noise, just take it out and lubricate where the cable goes in, my dads 4Runner has been makeing a cluster noise since weve owned it and its been good for 7 years now, and i probubly made the noise before we owned it, its really mostly from the cold
Old 02-03-2009, 08:17 PM   #10 (permalink)
fleet white
whatgoshere's Avatar
View whatgoshere's Photo Gallery
my cluster did the same thing.. what it was on mine is the magnets where dragging each other, I just recently fixed it with a nice paseo cluster w/ tach
1992 tercel 2-dr 5-spd 5e-fe. fleet white paint
whatgoshere is offline   Reply With Quote
Mechanical Oil Pressure Gauge Install Stillrunning 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-05-2007 05:12 PM
Gauge cluster question? 98corollaturbo Archived Corolla threads 3 08-08-2007 02:25 AM
Gauge Cluster Weirdness - Coolant Sensor + Drive Light Not Working JayBroni 3rd & 4th Generation (1992–1996 & 1997–2001) 5 07-07-2007 10:31 PM
Gauge Cluster Swap cheeba Camry & Solara Lounge 3 10-24-2003 03:28 PM
Gen. 2 V6 gauge cluster question xavior66 Camry & Solara Lounge 10 08-09-2003 05:38 PM
