93 Tercel Headlight Switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2008, 12:57 PM   #1 (permalink)
View snowmosled's Photo Gallery
Canada 93 Tercel Headlight Switch
Hello, I have a 93 tercel and the LOW beams won't work. The high beams are fine. Checked the fuses and they are OK. Someone told me it is the switch in the steering column. The arm the turns on/off the turn signals and headlights I guess.
Anyone know anything about this?
How easy is it to replace?
Thanks in advance
snowmosled is offline   Reply With Quote
Old 03-06-2008, 03:24 PM   #2 (permalink)
View thoughthard's Photo Gallery
It is not that difficult to replace.
Make sure to get one that corresponds to your year/airbag/non-airbag.
You can upgrade to a Paseo one also, so you can have intermittent wipers, if yours does not already. Direct swap, but you still have to follow the advice above.
thoughthard is offline   Reply With Quote
Old 03-06-2008, 03:54 PM   #3 (permalink)
Thanks. I don't have the intermitent wipers so maybe I will upgrade.
Would you know the proper name for the part I need?
Thanks
