Aftermath of my coolant problem
OK, here is what finally happened. If you recall, I got a new thermastat, and I had steam coming out my engine.
I finally found an engine shop, and they were very optimistic about my car (two other places pretty much said "it's the end"). By then, steam was coming out pretty much every orifice in the car. I shall never forget that horrible smell of coolant steam.
Took it to them, they said it was the head gasket. They had it in the shop for a week, did all sorts of stuff, and "while you are in the neighborhood" stuff, so I got a new timing belt and waterpump, valve stem seals (which have been leaking forever) and head gasket among other things.
I finally got the car back on Saturday evening. Sounded soo much better. Meanwhile, my car had been out of commission since mid-February, the month when my inspection sticker expired.
So today I took it right to the MVC inspection station. After all that engine work--I failed on emissions.
My car has NEVER failed emissions (its a 91, and I am the original owner).
I took it right back to the shop, and they said it could be that after all that work, there could still be coolant and crap floating around the exhaust system from the old problem, that has to work its way out. (I failed on HC and NO)
Does that sound true to you guys? Or could this shop have screwed something up?
The other problem is if you fail inspection in NJ, you can ONLY pass if you take it to a REF shop and have work done on the car, so it's not like I can wait for this excess crap to flow out of my car post-engine-work, and then go through the inspection again. No can do!!
I can't believe I shelled out over 4 figures, and I failed inspection!!
Any advice?
