1988 Tercel sarts and die - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2008, 07:09 PM   #1 (permalink)
View wingover's Photo Gallery
Hi There,
Everything was fine, the car started this morning like always but after 5 minutes driving, while standing in a red light it died.
When you turn the key and crank the engine it will start for 1 second and then die. (almost like when you leave the key it dies)
Help??
wingover is offline   Reply With Quote
Old 03-10-2008, 08:09 PM   #2 (permalink)
View Planetgoofey's Photo Gallery
Sounds like a vac leak- egr...etc , but could be a host of other stuff-(fuel pump-filter-electrical.. etc )the easiest is to
look for a disconnected or cracked vac hose first
"unfortunately, common sense is not common"
Planetgoofey is offline   Reply With Quote
Old 03-10-2008, 09:09 PM   #3 (permalink)
Thanks for the reply.
So i looked for hoses that are loose but all looks fine.
When i start the car it will idles fine for 2 sec and die. So i drip some fuel directy to the carb and it will idle for 6 sec and die.
If i pump the gas pedal quickly i can keep the engine running but rough.
seems to be the carb.
any help from here?
Old 03-10-2008, 09:16 PM   #4 (permalink)
fuel filter
Fuel pump
Carb
In that order
Is there a strong smell of gas?
PG
Old 03-10-2008, 09:43 PM   #5 (permalink)
Fuel filter fine
Fuel pump fine. pushing lots of fuel with no problem.
Carb??
no fuel smell. more like not enough fuel is getting to the throttle. maybe a blockage in the carb??
Old 03-11-2008, 01:31 AM   #6 (permalink)
Got spark
Got fuel to carb
No visible vac leaks..................................
did you check your EGR Valve?
What engine type---3A, 3AC, 3E ?
Carb is different on 3E
Peace
PG
Old 03-11-2008, 02:58 PM   #7 (permalink)
Spark's iridium and are new
How do i know what engine i have? 3e,3a..
I do have this plug on the firewall to connect and test equipment.
