Wiring difference between 94 and 95 models?
First time poster here...
I know that 1995 was the start of the 5th generation of the Toyota Tercel, however, is there a major wiring difference between the 1994 model and 1995 model? The reason I ask is because I own a 1995 toyota tercel that has the following problem: When I turn the ignition, start the car and begin to drive, the airbag indicator light stays on. When I brake, my front side lights will come on. When I turn my headlights on, the rear brake lights stay on whether I am simply driving or braking. My turn signals work fine, my dome light works some of the time and my headlights seems to function just fine, although I seem to go through a lot of lamps for the license plate. It sounds to me like this is a bad connection and from what I've been told, the problem is probably somewhere behind the dash? I'm having difficulty finding a repair shop that knows how to solve this problem, and the shops that I have visited are either unable or unwilling to find a wiring diagram for a 95 tercel. Could I point the mechanics to a diagram for a 1994 model, they seem much more common than the 1995 diagram for some reason.
So, if you can excuse a long first post, I'd like to say I'm glad to join this group and appreciate any help I am given.
