3e Valve Adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2008, 12:04 PM   #1 (permalink)
View burtonridr's Photo Gallery
3e Valve Adjustment
How the freak do you adjust the valves on these things?
I took it apart last night thinking it would be a simple 30 min job like on my old 22re engine.... No the rocker are hugs the sides of the valve on 2 sides, like a horse shoe shape around it. WTF!
I'm probably going to cut the tip of my feeler gauge with a dremel so it is only as wide as the valve stem, then it will fit in between the top of the stem and the rocker arm. It should work, anyone else know any tricks to adjusting the valves on these?
1987 Toyota Tercel
Mmmm...Gourmet Coffee
burtonridr is offline   Reply With Quote
Old 04-01-2008, 07:06 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
it is straight-forward. maybe a set of the offset feeler gauges would help you, but i've used the straight ones for years. the retainer nut is a 12mm and the set 'screw' is a #2 flat head. these engines require a slight drag of the feeler gauge. too tight will follow the cam well, and will also cause premature wear. too loose will cause chatter.
ToyotaTechGeek is offline   Reply With Quote
Old 04-01-2008, 09:05 AM   #3 (permalink)
I understand how to do it, I have done it before on other vehicles. On this one though I dont see how you could use a standard feeler gauge.
I'm supposed to measure and adjust the clearance between the rocker arm and valve stem right? Or is it between the set screw and the surface below it that should be measured for correct clearance?
This is what the valve stem and rocker clearance looks like on my 3E engine
1987 Toyota Tercel
Old 04-01-2008, 02:13 PM   #4 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
I just slipped the feeler under each cam lobe. It seriously takes no more than 20 minutes to get it apart, adjust them, and put it back together. Easy as can be.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 04-01-2008, 02:38 PM   #5 (permalink)
yeah, right under cam lobe.
Old 04-01-2008, 04:48 PM   #6 (permalink)
Oohhh.......
So you measure the gap between the cam lobe and the rocker arm, not the gap between the valve stem and rocker arm?
weired
1987 Toyota Tercel
