I will keep researching. From what I read, the 3EE and 5EFE transmissions do require 1 small modification, that was the exact wording that I read, and with the modification, they work fine. But here is a post off a different forum saying NO WAY... I will simply keep researching because I am considering the 4AGE myself, but don't want a new tranny because I love high gears. I drive on the highway every single fricken day, at 55mph!! I don't like low gears at all.
chadwithporsche
06-07-2006, 02:38 AM
Hey, I have an 89 tercel and I just removed the engine to try a 4age. I know alot of you guys say that the tranny (4spd) will fit and some say it wont fit. It definitely wont bolt up but there is another problem I see being that the 4age has a pilot bearing and the other corolla transmissions dont use a pilot bearing. Ive heard any A series engine's transmission will work, but is it safe to assume that I must have a fwd 4age transmission? Im not too concerned about the axles because I can weld and balance them."
and ANOTHER POST by chadwithporsche:
"Hey guys, I completed the 4a-ge swap into my tercel ez. I just thought I would tell you definitively what I did and what worked. I used the c50 transmission with an mr2 flywheel. I used the corolla axles and they bolted right up. All I had to do was make custom mounts for the engine. With the c50 transmission and the 4age the crank pulley is about 1/2 inch from the frame and the drivers side frame had to have a pocket cut into it for the transmission to fit into. The exhuast tunnel even lines up with the gap in the oil pan. If I hadnt used a rwd 4age then I guess the water lines would be easier since they are on the passenger side facing the fire wall now. All in all its not that bad of a swap if you have some steel laying around and can weld. Ill try to post some pics if I can figure out how too lol. ( Im a fabricator not a computer whiz). If you guys want to do the swap then just ask me about it because I figured everything out the hard way. Thanks for all your help."
From
http://www.toyotanation.com/forum/ar.../137802-1.html
AND ONE MORE BY wedge:
Third, is of course the 4A-GE 16v. 1.6l, 16 valve DOHC. Power ranges from 115hp up to 140hp depending on the year. It's a more difficult swap to do. It requires custom made engine mounts, because the engine is of a different family. Luckily the tranny will bolt on, but it requires 1 small modification to be made first."
http://www.toyotanation.com/forum/ar...c/19926-1.html
AND TO ADD TO THE DANG CONFUSION!!!! HERE IS THIS BY Donald:
"The '87-'94 Tercels have a C150 (5spd) or C140 (4spd) manual transaxle. (Haynes manual)
The '92 Paseo, I guess all Paseos have the C150. ('92 Paseo shop manual)"
gearing possibilties..?
