4a-GE throttle body on 5e FTE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2008, 12:03 PM   #1 (permalink)
Tumaka
View Tumaka's Photo Gallery
I am in the process of converting my 4e FTe into a 5e FTE.
My mechanic has an idea to bolt a throttle body from a silver top 4a GE onto the head of the 5e.
Has anyone ever done anything like this?
Is this really practical?
If so what has to be done and what good will it do to the engine?
Tumaka is offline   Reply With Quote
Old 04-10-2008, 04:31 AM   #2 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
i think they are the same bore size. it will probably bolt right up most of them do just have to deal with the tps sensor.
4speedsleeper is offline   Reply With Quote
Old 04-10-2008, 09:47 AM   #3 (permalink)
View tgidavid's Photo Gallery
If I remember right, the silvertop uses ITBs. You will need to make a custom adapter, and upgrade the side feed injectors. ALso, you will need to make an enclosed airbox since your keeping the turbo. The stock airbox cannot hold much boost. Hook up a vacuum distribution block to all the runners, syncronize the left and right batch of throttles, run custom fuel and fuel return lines for the side feed fuel rail. Oh and make sure the ITB adapter has provisions for the injectors. I believe the the silvertop injectors bolts to the head. ANd then your done!
tgidavid is offline   Reply With Quote
Old 04-12-2008, 11:15 PM   #4 (permalink)
Banned
doh, I was thinking the 16 valve sorry
