need help with my tercel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2003, 08:54 PM   #1 (permalink)
View Skylineracer59's Photo Gallery
Hey im new and I need some help I have two cars my 94 tercel and 88 corolla sr5
My tercel is mest up I have to swap the engine and I wanted to know if I could drop in any other engine that fits on and which ones like a corolla engine
Its a 94 tercel DX auto
Skylineracer59 is offline   Reply With Quote
Old 12-11-2003, 08:57 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
91-94Paseo engines go right in, get the ECU and the gauge cluster also.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 12-11-2003, 09:11 PM   #3 (permalink)
Does it go in their perfect those it bolt on the tran perfect
any other engines that fit on
If I drop an engine from a different car what else do I have to change
Old 12-11-2003, 09:31 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
That's pretty much the most straight forward swap. Going to larger car's engines are going to require their trannys also, and then the axles might not fit, plus the motor mounts may not be in the correct place, wiring, exhaust, ....
You can get a jdm Starlet clip, but it requires a lil fancy wiring too.
雄のハヤブサ
Old 12-11-2003, 09:44 PM   #5 (permalink)
so the paseo engine is the only one that fits on their perfect
with out having to do any modifications
thanks for ur reply
