Water Pump Replacement On Paseo 1992 - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 10 Old 08-19-2009, 02:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question Water Pump Replacement On Paseo 1992
Hi to all i an new to this forum, and i an looking for help ,i need to change the water pump in a toyota paseo 1992 1.5 sohc ,and i an unbale to remove one of the bolt and i dont knoe if i have to remove the engine mount and brackets or if ther is any other way to du it
thanks
VIRGOPELO is offline
post #2 of 10 Old 08-19-2009, 04:00 PM
BLARRGH!!!!
Madcat's Avatar
Quoted: 0 Post(s)
Remove the alt and then take the pump extension off with the pump attached.
Pics:
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline
post #3 of 10 Old 08-19-2009, 08:36 PM
N/A bites
Tercel GTS's Avatar
Quoted: 79 Post(s)
Don't forget to change the O ring in that rear pipe.
雄のハヤブサ
Tercel GTS is offline
post #4 of 10 Old 08-19-2009, 08:53 PM
BLARRGH!!!!
Madcat's Avatar
Quoted: 0 Post(s)
Good point. I forgot about that being there.
Jim
Madcat is offline
post #5 of 10 Old 08-19-2009, 11:04 PM
fleet white
whatgoshere's Avatar
Quoted: 0 Post(s)
uhhh sohc? well thats a first
1992 tercel 2-dr 5-spd 5e-fe. fleet white paint
whatgoshere is offline
post #6 of 10 Old 08-20-2009, 06:50 AM
N/A bites
Tercel GTS's Avatar
Quoted: 79 Post(s)
I didn't catch that. He's right, all Paseo should have dohc but it's still the same water pump setup.
雄のハヤブサ
post #7 of 10 Old 08-20-2009, 07:25 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Wink
hi thanks to all for you fast replay , i will do it today and yes this one is a sohc but the water pump set up looks the same as the one in the picture
thasnkssssssssssssss
post #8 of 10 Old 08-20-2009, 11:45 AM
fleet white
Quoted: 0 Post(s)
hmm somone must have swaped a 3e-e in to it.
post #9 of 10 Old 08-24-2009, 08:11 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question
hi thanks for the replay i change yesterday the water pump ,but i have a question for you guys in the intake manifold of this engine shows 16 valve but it looks like a single cam so it will be 16 or only 8 ?
thanks
post #10 of 10 Old 08-24-2009, 12:47 PM
N/A bites
Tercel GTS's Avatar
Quoted: 79 Post(s)
16 valve is dohc. The sohc is a 12 valve. Just because the timing belt only goes over one pulley doesn't mean it's sohc.
How about some pics to clear this matter?
雄のハヤブサ
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Tercel, Paseo, Starlet, and Sera Forum
User Tag List
Linear Mode Linear Mode
Back
