Timing Belt Change Interval for '97 Tercel 1.5L - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2004, 09:14 PM   #1 (permalink)
View chuckhammer's Photo Gallery
Anyone know what the change interval is for the timing belt on a '97 Tercel 1.5L?
Ours has ~95k miles on the original unit. Thanks.
Sic Semper Tyrannis
chuckhammer is offline   Reply With Quote
Old 03-19-2004, 07:40 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
60-80 thousand miles. You are on borrowed time.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-19-2004, 08:27 AM   #3 (permalink)
Shit. I was afraid of that.
Sic Semper Tyrannis
Old 03-19-2004, 08:58 AM   #4 (permalink)
If the belt does let go, will the engine's design permit valve-to-piston contact?
In other words, will it still only be a matter of swapping the belt or will there be serious damage done?
Sic Semper Tyrannis
Old 03-20-2004, 04:47 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Just took in a 96Escort at my shop, 76,000 miles, timing belt popped. $1600.00 repair since it bent the valves. That darn belt sure woulda saved them some cash....
雄のハヤブサ
Old 03-20-2004, 07:13 PM   #6 (permalink)
Yeah, it's getting done Monday. New brakes as well.
Sic Semper Tyrannis
Old 04-11-2004, 08:50 AM   #7 (permalink)
View gregj66's Photo Gallery
5EFE is a non-interference engine.
gregj66 is offline   Reply With Quote
Old 04-11-2004, 10:51 AM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Does that mean you'd rather wait for a belt to pop than do normal maintenance? I hope you don't look at oil changes in the same light.
雄のハヤブサ
Old 04-20-2004, 09:37 AM   #9 (permalink)
Not at all, nor was it suggested to run it until poppage
Just clearing the air regarding valve destruction.
BTW, the '97 service intervals are "severe" service and the '98 intervals are "regular" use. I chose to replace my Timing belt at 150,000 km as per the '98 service schedule since it's the same engine and timming belt.
The belt was in fine shape when I changed it, but no need to go anyfurther..
G.
