92 paseo AC quit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2010, 09:31 AM   #1 (permalink)
View amx1397's Photo Gallery
92 paseo AC quit
Hi every newbe here but really need your help this is my drive to work car and in south fl. i need the ac,,,,, I can't find the #8&9 fuse for the AC, ( if that is the problem) the book says it is behind the pass kick panel it is not I jumped the compresser and added r 34 but the AC light keeps on flashing when you push it to turn on the AC any help please. jim
amx1397 is offline   Reply With Quote
Old 04-18-2010, 01:27 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
The interior fuse panel is located to the left of the steering wheel. The underhood fuse/relay box contains the compressor relay. If the light is flashing, chances are good it has leaked out most of the charge and the low side switch is stopping the compressor from running. If your belt is loose and squealing, this problem can arise due to intermittent drive of the compressor. Common leak areas are the hermetic o-rings on the lines and the filter/drier. Next would be the compressor shaft seal. Did you jump out the pressure switch? Its a bad idea to jump out a safety and add refridgerant at the same time. What was your low side pressure before you added the R-134a?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 04-18-2010, 02:01 PM   #3 (permalink)
well my son came over and he found a wire that was broken,,, i had jumped the compresser and the ac worked good,, we connected the wire and now ,,,we got AC thanks all for your help, jim
Old 04-19-2010, 08:08 PM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Its sooo nice when its a simple problem. AC systems are a PITA to work on and troubleshoot. Good to see you fixed it.
