1999 Tercel Thermostat Housing Bolt Broken
I have a 1999 Toyota Tercel, Manual Trans, 1.8 car. I was replacing my thermostat and the lower bolt/stud broke while trying to remove the thermostat housing. I have not run into this before. Can I ask if this bolt is something you can replace? Im wondering if it is part of the water pump or if I can purchase the bolt and heat the old one out. Im not sure if it is threaded all the way in. Any help would again be much appreciated.
Thank you
