Tranny Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2010, 11:34 PM   #1 (permalink)
Tercel
3ee4banger's Avatar
View 3ee4banger's Photo Gallery
Tranny Oil
Is there any way to put oil in a 93 5 speed tercel with out some kind of special pump because my Tranny has a small leak and it's starting to whine
93 Tercel 5 speed
3ee4banger is offline   Reply With Quote
Old 04-28-2010, 02:36 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
It's a pita but the bottles with the cone tip will do it.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 04-28-2010, 11:34 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
A 2-3 ft long section of 3/8" clear hose attached to the tip of the bottle works wonders. You can feed the tube into the fill hole, then send the other end up behind the rad. Put the tip on the hose and you can fill it while standing. Just make sure you the hose on tight or it might pop off while your squeezing the bottle.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
