96 paseo transmission out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2010, 01:42 AM   #1 (permalink)
View reign78's Photo Gallery
I've got a 96 Paseo and I'm looking to find a used transmission to replace the one that went out. What year ranges and other vehicles transmissions will match up with the 96 Paseo? It is a manual transmission.
reign78 is offline   Reply With Quote
Old 05-01-2010, 09:42 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Check out www.car-part.com The site returned several hits in your state, one was particularly close. Whitey's Wrecking in Spokane. The trans is from a 92 paseo and will fit. However, I would recommend getting one from a 96 paseo or 96+ tercel. The ratios for 3rd, 4th and 5th gear are slightly taller helps keep the rpm's down a bit.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
