raising alt voltage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2010, 04:26 PM   #1 (permalink)
ambyrell1's Avatar
View ambyrell1's Photo Gallery
raising alt voltage
I read about this http://www.scoobymods.com/raise-your...ge-t10547.html, my question is which wire on a 93 tercel would i put this on?
ambyrell1 is offline   Reply With Quote
Old 05-09-2010, 06:14 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Looking down at the alternator from the pass side of the car with the plug still connected it should be the wire to the right or closest to the engine.
http://search.waiglobal.com/partsear...spx?part=IN437
http://search.waiglobal.com/bomsearc...=1-1839-01ND-2
http://search.waiglobal.com/vehiclel...=1-1839-01ND-2
a few links you may like^^
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
The Following User Says Thank You to Tercel GTS For This Useful Post:
ambyrell1 (05-11-2010)
Old 05-09-2010, 06:27 PM   #3 (permalink)
ambyrell1's Avatar
i have a custom built 220 amp alt, just wanted to bump voltage from 14.7 to 15.0.
Old 05-10-2010, 06:47 PM   #4 (permalink)
Drives 1 loud yota!!!
View steveokinevo's Photo Gallery
^ where did you get that from??? i need a higher powered 1 for all my stereo stuff
steveokinevo is offline   Reply With Quote
Old 05-10-2010, 06:59 PM   #5 (permalink)
ambyrell1's Avatar
1.888.MECHMAN, they have a 150amp and the 220amp. what do you have system wise? I have a custom built 15", in 4.5 cubes tuned to 38hz, with two Discus2000.1 strapped, it will take your breath, literally.
Old 05-10-2010, 09:08 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
I'd like to see the actual output. Stop by a local alternator shop and get them to load test it for you if free.
雄のハヤブサ
Old 05-10-2010, 10:18 PM   #7 (permalink)
ambyrell1's Avatar
wouldn't do much good here is a link explaining why-
http://www.stevemeadedesigns.com/boa...-alt-properly/
Old 05-11-2010, 06:30 AM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Let me start by saying this response is to the supplier, not you.
That doesn't just step on toes, that's a direct insult.
Your hometown rebuilder.
1. They are just that, a rebuilder. They know very little about the design and function of an alternator. They just repair factory alternators by replacing parts. They also will tell you your crazy when you tell them an alternator can do 200 amps. They dont understand what they dont know.
I'm a hometown rebuilder. I deal with tech people at regulator and diode manufacturing facilities to explain problems that arise from modifying computer controlled charging systems and have a thorough understanding of what makes them work and how to improve them.
2. When they do test an alternator,(on their bench), they almost always use small aligator clips to the battery post of the alternator. Probably 8 or 6 gage. Would you connect your 2000 watt amplifier to your battery with 8 gage? I dont think so....for obvious reasons.
I'd rather test the alternator on the vehicle where i can see it perform in a real world situation however my bench is setup to replicate it quite close. I use bolt on terminals for anything over 100 amps.
3.On their bench test, they more than likely will never go over 3500 to 4000 rpm. Dont freak out, this is alternator rpm, not engine rpm. An alternator should spin atleast 3 times faster than your motor. The industry standard for max output is to be tested at 6000 rpm. Approximately 1500-2000 engine rpm. 3500-4000 is just above idle.
My bench has a 5hp 3 phase motor with a 6" pulley to a 2" pulley. I can spin an ambulance alternator at 15,000rpm but most troubles are at idle.
4.When a load is applied, it should be gradual. 75% of the test stations that are common to rebuild shops are either on.... or off when it comes to loading. (typically 300 amps) There is no way to ramp up the load presented to the alternator. When you load an alternator with an instantaneous 300 amps, the regulator does not have time to react and the reading will be substantially lower. It also depends on the type of regulator used. Some vehicles must have a time delay type regulator due to the car either being so new or aftermarket not available yet. When you load the alternator down, you keep going until the voltage level falls to that of the battery. Which is typically 13.0-13.5 This way all current being pulled is is being produced by the alternator, not the battery. You then take the current reading off the battery post of the alternator.
You may notice this tester has a knob and no switches. It is applicable up to 600 amps. You can adjust how quick the load comes on by how fast you turn the knob. For accurate high amps readings it must be tuned like an old am radio. The amps are read by a remote cable that attaches to the wire near the alternator. Too close and it picks up false magnetic signals.
Of the 6 local shops I feel confident in 4 to test it properly. I understand not all shops deal with modded parts.
雄のハヤブサ
Old 05-11-2010, 08:17 AM   #9 (permalink)
ambyrell1's Avatar
i didn't write that, it's a link I was given when I had problems when installing my alt, turned out to be wiring harness.
Old 05-11-2010, 10:05 AM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
That's why at the top I wrote this reply was to the supplier, not you. Don't want you to think I took the link as you insulting me.
雄のハヤブサ
Old 05-25-2010, 12:31 PM   #11 (permalink)
N/A bites
Tercel GTS's Avatar
I registered at that forum as F540HD (the part number of my favorite voltage regulator) and replied to that thread. I can't wait for a response.
雄のハヤブサ
Old 07-03-2010, 11:56 AM   #12 (permalink)
ambyrell1's Avatar
Did you ever get a response?
Old 07-05-2010, 01:24 PM   #13 (permalink)
N/A bites
Tercel GTS's Avatar
No.
F540HD
120db
Group:
Members Posts:
14 Joined:
24-May 10 Posted 24 May 2010 - 04:00 PM
Dom,
Are you serious? You really think no rebuilders are smart enough to test a high output alternator? I use a snap-on for testing on vehicles that displays over 400 charging amps and doesn't use aligator clamps. Please climb off your high-horse and enjoy a little reality. I see alternators pass over my bench that will make over 300 amps each. I'd love to test one of your units and be honest about what the performance level truly is.
Bill
雄のハヤブサ
