Harmonic Balancer Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2010, 07:08 PM   #1 (permalink)
... It still runs...
View bkftl's Photo Gallery
Lightbulb Harmonic Balancer Question
Hi again everyone, thanks for reading my post:
Last weekend we removed engine and cleaned it up, removed Harmonic Balancer. To get to timing belt. Look up my project post if u want to know more bout that.
This question is about the "Harmonic Balancer" Here is a picture of it. Looks like there is a large chip on the outer rear ring. Its NOT rusty exept the paint is chipping. Whole thing seems preaty SOLID. I dont know what could have made this chip.
Being around 100$ for a new one . (And i want to save money for interior repair) I was wondering if you guys think it needs to be replaced at all? It did not make any sound or anything. Should I grind the Chip a bit so its not sharp? Which side should i face the chip: toward timing belt cover or on toward the front like on the picture?
Rubber is a bit beat up due to our horrid attempts at removal of Harmonic balancer without special tool. (Borrowed form Autozone) but its no less then 3mm so it seems ok. Might not be visible completly.
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 05-10-2010, 08:14 PM   #2 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
UUMM thats not supposed to come apart.
The timing mark should be around the 1 O'clock position not 5.
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
The Following User Says Thank You to Madcat For This Useful Post:
bkftl (05-10-2010)
Old 05-10-2010, 08:31 PM   #3 (permalink)
Whaa!? Thats why the other TIMING belt cover was damaged!!! Thanks Jim
What do u mean? Am i missing Parts? Is the REAR LARGE wheel supposed to be attached to that rubber ring? Attached how? Glue?
Did my rubber thing shrink so its loose?
Old 05-10-2010, 09:07 PM   #4 (permalink)
BLARRGH!!!!
Madcat's Avatar
The large pulley and its inner hub are press fit together, with the rubber as an isolator. If it came apart then the rubber has shrunk from age/time.
I'd recommend getting another either from a JY or new from dealer.
Jim
bkftl (05-10-2010)
Old 05-10-2010, 09:10 PM   #5 (permalink)
Thanks a lot Jim that clears a lot of mysteries. Will get a replacement.
Old 05-10-2010, 09:14 PM   #6 (permalink)
BLARRGH!!!!
Madcat's Avatar
If you get a used one from a JY make sure the timing mark is at the 1 O'clock position while the inner keyway is at 12.
Jim
bkftl (05-10-2010)
Old 05-12-2010, 11:18 PM   #7 (permalink)
Went to JY, was hard to find it but GPS helps a lot, got 2 different ones.
I cleaned and grinded the chips so they are not sharp.
Problly gonna use one ...
... and sell another if anyone needs let me know.
Thanks for ur info once again Jim
Old 05-12-2010, 11:34 PM   #8 (permalink)
BLARRGH!!!!
Madcat's Avatar
No problem. Glad to help.
Jim
