supported on the counter weight not cap. thinkin' i spun crank..... no rod knock. i can tell a rod, wrist or crank end. not that. if there is any knocking, it's a very low frequency and i can feel it in the steering wheel. thats why i was leaning toward a crank. my first fwd car, but i though the vibration could transmit to the wheel via drive line. unlike rwd. but thats why i asked hear....
feed back carb, water, k, seems very plausable. since the wifey told me today she heard some pinging. ck that. ty.
i'd like to think you're spot on w/the sensor. cheap enough to r&r. may, that is contributing to the vibration.
thinking now, i should check the balancer. my old one was chipped and i use one from a yard. when i did the pump last summer. mine was cracked
exactly like this
Harmonic Balancer Question
i mean exactly. same length same place from the notch. i also found a dent on the inside bottom of the t-cover and figured a rock or something got wedged up there. what are the odds with a belly pan/diaper installed.
i knew you guys would make me think.. wish i had good ears.....
i'm running autolite plugs like a good american block should. but what do you guy's run? nips?
thnx fer the emotion tap. both of you.
