92 Paseo AT idle dropped when warm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2010, 11:49 AM   #1 (permalink)
View icmac's Photo Gallery
My 92 Paseo AT with 120K miles on it. Idle was rough, car was shaking at cold and warm. I replaced 4 plugs (wires are good) took care the idle when COLD (800 RPM) but it it got warm, idle dropped again, car shook but not as bad as prior to plugs replace. Any suggest? I couldn't locate the idle adjust screw so I can try a "quick fix". Thanks
icmac is offline   Reply With Quote
Old 05-11-2010, 05:13 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Any misses or hesistation during acceleration? Have you checked the condition of the cap and rotor? Throttle body may need to be cleaned.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 05-11-2010, 08:41 PM   #3 (permalink)
92 Paseo idle dropped when warm
The accel is fine, the cap looks fine from the outside, no crack, perhaps rotor need to be replace.
I'm trying to get some inputs so I'm going to work on it this w/e, thanks 96Paseo.
