The whole car was purchased as sorta blind buy, I never even saw it for a while, my relative got it for me.
We removed Engine cuz timing belt didnt have a cover at all, and was covered with OIL. I heard thats realy bad.
After engine was removed i discoved parts missing or brocken, like timing belt cover, harmonic balancer was busted, bearings on timing belt pulleys were damaged.
I also noticed lots of oil above the Oil Filter. What could that have been? It
was the seal, it has a lot of burned OIL. Apparently previos owner or whoever reparied it, tried to remove head and striped 2 Screws. Then they closed the head back up and sold the car. We removed one screw and cut another with Dremmel, because the Screw remover nail thingey BROKE inside, so it could not be drilled. Gasket below is what they probably wanted to change was leaking obviosly it had oil all over inside the gasket.
Oil pan didnt even have a gasket, they used Liquid gasket, which seemed realy badly done, Especialy around the CLUTCH.
Full gasket set was only like 40$ with free shiping from ebay. So i figured why not redo gaskets and get a look inside. If the gasket set is like it says it will have the round seals for the crankshaft and such, i will try to replace those too. I never been inside the engine that far before :P
I has no money for machene shop right now, maybe next build. I just need a reliable car for college, after reading here offcourse i wanna do Turbo swap
but not right now
Thanks for youre input dude, I realy appreciate it.
I shall check out those seals.
