tercel 95 speedometer dead - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2010, 09:38 PM   #1 (permalink)
allpr0h's Avatar
View allpr0h's Photo Gallery
hi there
my bro is happy owner of a tercel 95, we had few problems with the car like had to replace brake lines and do the brakes, mostly
now hes doing 230km a day (wtf) and his odometer (distance) stopped working and his speedometer too
you folks got any idea? not sure if the speedometer is a cable, if yes any clue of what happened? the cable goes in the tranny??
any advices would be nice
thanks a lot
allpr0h is offline   Reply With Quote
Old 05-19-2010, 10:02 PM   #2 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
The speedo is run by a cable that threads into the differential housing. It most likely broke. unscrew it from gearbox and pull it out. remove the gauge cluster to make sure it didn't leave any pieces behind.
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
Old 05-19-2010, 10:18 PM   #3 (permalink)
... It still runs...
View bkftl's Photo Gallery
That cable is a tricky one, it took me a few tires to remove it,
its held by a tab which is held by a small screw...
Then the actual cable can be unscrewed.
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 05-22-2010, 05:13 PM   #4 (permalink)
View WilliamRobert's Photo Gallery
Before you take too much apart, it might be better to figure out exactly what the problem is. Personally I would unscrew the cable from the transaxle as stated above. Then I would attach a drill to the end of the cable and spin it. Have a person sitting in the driver's seat watching the the speedometer. If it moves that means that the cable and speedometer are good and the problem is in your transaxle. The speedo gear in the diff is made of plastic and sometimes they break, for one reason or another.( old age, hitting a curb, spinning your wheels on ice then hitting pavement, etc, etc.)
If the speedometer doesn't register when you have your drill on the cable then you know that the problem is the cable or the gauge. Both are very straightforward to repair/replace and parts are easy to find at your local wrecker.
WilliamRobert is offline   Reply With Quote
Old 05-26-2010, 04:23 AM   #5 (permalink)
allpr0h's Avatar
thanks a lot folks
if i get the chance ill have a look with my bro, hope it all goes well..
Old 05-26-2010, 08:05 AM   #6 (permalink)
View THA REAPER's Photo Gallery
European Union
Originally Posted by allpr0h View Post
thanks a lot folks
I AGREE WIT WILL ROBERT ON THIS ONE
THA REAPER is offline   Reply With Quote
