Since you have an R-12 system, you should have a blue and red cap for the schraeder valves. Find the red cap on the high side line. The pressure switch should be near it on the same section of line. Look for a wire harness plugged into the line. If that doesn't work, find your high side line at the compressor(its the smaller of the two lines). Follow it out until you find the harness. Good luck. Is your system not running?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
