91 Tercel 3ee - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2010, 08:13 PM   #1 (permalink)
View jregamey's Photo Gallery
Question 91 Tercel 3ee
I have a 91 tercel with a 3e-e motor,(auto) And basicly needs a new motor. I rather do a swap over a rebuild.
Ive gone to pick a part and theres a nice 1999 tercel with a dohc 16valve engine with ONLY 130xxxkm. also automatic tranny. 5e-fe im assuming
If i took out the engine would it bolt up to my 91 tranny? Or if i had to i woudl take the tranny aswell.
So would this 5e-fe engine fit right up nicely? Would i need to take along the 1999 engine mounts?
Is there a page for a 5efe swap to a 91 tercel?
I gotta get this done as i have to keep this car for atleast another 6 months to gain credit for a new car.
Thanks for the help!
jregamey is offline   Reply With Quote
Old 05-25-2010, 10:41 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
If you get the 99 5efe you will need the ecu and do a custom harness. The 99 has no distributor but instead coil packs. If you find a 92-95 Paseo the 5efe in that has a distributor and can be run on current wiring. Check prices on http://car-part.com and see what tigerjdm has currently as well.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 05-26-2010, 07:40 PM   #3 (permalink)
thanks for the help, Pick a part here has 92 paseo dohc Standard, and a 96 auto. 96 is again too new eh?
What about what do i need to keep and grab if im sticking it on my auto tranny?
Ill be checking other places around town also.
How u said i need a costom harness how difficualt would that be? also these motors should all bolt onto my tranny? Thanks!
Old 05-26-2010, 10:41 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Bolt to the trans yes but I'm not sure about the flexplate.
The custom harness would be needed for the DIS engine. If you're really experienced with wiring it isn't too bad but otherwise pay somebody like GT_REVVA to make a harness for you. You would also need the ECU.
Don't pay over $500 for an engine until you check with tigerjdm. They have some really good deals there.
雄のハヤブサ
The Following User Says Thank You to Tercel GTS For This Useful Post:
GA noob (05-27-2010)
Old 05-27-2010, 07:39 PM   #5 (permalink)
found a 92 paseo but with standard tranny, unknown km also.
also found a 95 tercel 5efe again with coil packs i guess, All i would need would to modify the harness? Icant seem to find anything about this. instructions. i dont see why anything would change if i just have the proper ecu for thaaat motor...
I wouldnt mind how to do the harness as my dad is familoir with stuff like this. Thanks again!
Old 05-27-2010, 07:59 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
The safest way to try it is get a harness for your car and one from the donor car. Let your dad try taking the engine stuff out the donor harness and swap it with the engine stuff from your harness. Then your accessories have their wiring and the engine has it's wiring.
Now the bad part.
The DIS engines are OBD2 and the car is OBD1. You may need dash wiring as well. I'm really not sure as I've never messed with OBD2 wiring. Open the ecu of each and compare the small plug. See if they have the same pin outs.
雄のハヤブサ
Old 06-05-2010, 07:46 PM   #7 (permalink)
View fanorpner's Photo Gallery
I would just rebuild the 3ee as long as you didn't spin any bearings or throw a rod. They are so easy to work on. Everything you need can be bought on ebay for $250.
fanorpner is offline   Reply With Quote
