Spark plugs - is it trying to tell me something? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2010, 12:53 PM   #1 (permalink)
View AresROC's Photo Gallery
Question Spark plugs - is it trying to tell me something?
While doing the cylinder compression test (Thread), I pulled out the spark plugs, and found 1 of them to be different than the others:
Spark plugs, cylinders 1~4 from left to right.
Those are NGK Platinum plugs, two days old. All plugs still have a pristine white ceramic tip, except for cylinder 1's. What is it trying to tell me? Am I burning oil or running rich on cylinder 1? Only one side of plug 1 is stained, facing the camera. The other 3 sides are clean... Please help!
AresROC is offline   Reply With Quote
Old 05-27-2010, 09:03 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Thats only some minor discoloration. Nothing to worry about. The ceramic insulator on all the plugs will look like that as they wear. Running rich would show up as a wet plug or a black carbon coating. Burning oil usually shows up as white ash that will flake of the ground electrode.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
The Following User Says Thank You to 96paseo For This Useful Post:
AresROC (05-27-2010)
