popping sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2010, 11:15 PM   #1 (permalink)
View turtle93's Photo Gallery
popping sound
My 93 terc makes a corn popping noise after warming up when cruising on the freeway.Go below 60 mph the sound goes away.Very intermittent. Sound seems to come from under the passenger footwell. I've shut off the motor and coasted but it still pops. I dont think its suspension or driveline, almost seems like detonation in the cat. Any thoughts?
turtle93 is offline   Reply With Quote
Old 05-30-2010, 06:24 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
If it makes that sound when going over small bumps, you may have bad FSB bushings. When sway bar bushings go bad, they tend to make a "popping or banging" sound because the bar is banging up and down inside the bushing. Control arm bushings and strut mount are other items to check. They can make a similar noise if they go bad. Doubt its anything related to the cat since the noise was still present with the engine off.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 05-30-2010, 08:28 AM   #3 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
+1 on the supension parts. Jack that puppy up and give everything a good lookover. If nothing seems bad go to an empty parking lot and turn the wheel hard left/right and do circles to test if the CVs are making the noise.
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
Old 05-30-2010, 07:20 PM   #4 (permalink)
This is a rapid fire, although random sound.Any manipulating the steering makes no difference. It comes on suddenly, always when cruising on the Freeway. When you go below about 55 it starts slowing down in rhythm,, then stops. Has a percussive snap to it, instead of a rattling,knockingness.
I do have the EGR temp sensor code come on every so often. (code 71)
Old 05-31-2010, 12:47 AM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
If your engine is running properly, no stumbles or hiccups, I'd still say its suspension or maybe body related. Keep in mind the RF FSB bushing and control arm bushings are right beneath the front section of the passenger floor board. The temp sensor code is likely thanks to plenty of carbon buildup covering the sensor.
Old 05-31-2010, 05:09 PM   #6 (permalink)
View WilliamRobert's Photo Gallery
might sound dumb, but is everything secure underneath? Maybe you have a loose heat shield that starts flapping in the wind. You would think that if it was an engine or exhaust fault, that once the engine was warm and started making the noise at 60mph but went away at 50mph, that you could pull onto a side road, put it in 2nd gear and rev the engine at the same RPM that you have at 60mph, and have the noise come back.
To help in diagnosing your fault you need to figure out if the noise is related only to speed, engine load, gear selection or engine RPM. That way you know where to look; engine, transmission, axles, tires, exhaust, the beer can falling out of the trunk, etc, etc.
BillyBob
WilliamRobert is offline   Reply With Quote
Old 06-28-2010, 12:43 AM   #7 (permalink)
See the next thread...finally found the noise!
Old 06-29-2010, 10:32 AM   #8 (permalink)
View PaseoDave's Photo Gallery
Why didn't you just post the findings in this thread????
PaseoDave is offline   Reply With Quote
Old 06-29-2010, 11:01 AM   #9 (permalink)
Certifiably Insane
96paseo's Avatar
The hell do you care? Is it gonna kill you to read the other thread? You don't spend nearly enough time here to even think about advising others about how to post. Starting an new thread or not is their choice.
Old 06-29-2010, 11:08 AM   #10 (permalink)
Ignorant frackers like YOU is why I don't post much on this forum.
