Oil Darkens Quick - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2010, 01:31 PM   #1 (permalink)
View turtle93's Photo Gallery
Oil Darkens Quick
The oil in my 93 tercel has been getting dark within 1000 miles lately. Motor was rebuilt a year ago, and oil stayed clean, but now the oil is darkening fast. I use Valvoline 10-30. Doesn't use oil and the compression is 180 across. Ideas?
turtle93 is offline   Reply With Quote
Old 05-31-2010, 02:49 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Sounds like a ring is sticking to a piston even though the compression shows good. Next oil change before you start try pulling the plugs out with the engine warm but not hot. Pour liquid carb cleaner into the cylinders so that the pistons are completely covered. Rock the crank back and forth a litle to ensure the liquid seeps into the ring lands of the pistons. Let it set for an hour. Then spin the engine while plugs are still out to expell excess liquid.
Change oil then reinstall plugs.
The first oil after doing this will darken even faster but after that should slow the darkening. If this doesn't affect it you may have compression seepage at the head gasket.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
