Originally Posted by Starkidd813
Well I released some 134a from the ac system, and it doesnt draw as much power. However it is still very noticeable. Also where is the idle up valve?
What good would releasing the refridgerant do???
Its VERY ILLEGAL to do that. The idle up is near the ECT and charcoal canister VSV. Please refrain from crack pot repair techniques unless your trying to prevent your A/C from working entirely. I would expect you need your air conditioning this time of year. You can burn out a compressor with an undercharged system. And futhermore, there is a noticeable decrease in power when running the A/C and its normal.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.
New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
