DLC Test - VF1 & E1 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2010, 01:21 PM   #1 (permalink)
View AresROC's Photo Gallery
Gen1 DLC Test - VF1 & E1
I have a question on the Data Link Connector (DLC) VF1 & E1 test.
Supposedly when you connect the VF1 & E1 to a voltage meter, it will tell you what the ECU is doing to compensate for lean or rich conditions.
At idle, if it reads 5 v the ECU is adding more gas to compensate for lean, and 0 v if the ECU is compensating for rich conditions.
With my tests, my 93' Paseo reads a consistant 2.25 volt at idle, varying by 0.01 v. When car is coasting to a stop, the reading jumps toward 0 volt, then back to 2.25 volt.
Can I speculate that under optimal condition, the VF1 & E1 should show 2.50 volt, and my 2.25 volt indicates the car is running rich some how? TIA!
93' Paseo - 170K Mile
NGK-BKR5E Platinum Spark Plugs, Bosch O2 Sensor, ECT
20w50 Oil, SeaFoam, STP Oil Treatment, Berryman B12 Chemtool
AresROC is offline   Reply With Quote
Old 06-14-2010, 04:33 PM   #2 (permalink)
So I found out the VF1 on DLC1 is a serial output stream connector. This won't help me much, unless I build an OBD-I serial monitoring tool.
I found a link: http://toyota.kgbconsulting.ca/wiki/...rial_Interface
with a software in Russian that can decode the communications.
Should I embark on building such a tool with a laptop, or is there a better way around to monitor my Paseo's condition?
Old 06-16-2010, 11:48 AM   #3 (permalink)
Failed. After much work to translate the Russian menu and documentation, building custom serial cables out of network console cables and Cat 5 cabling. Putting on two 1uf capacitors in parallel, etc...
Turns out the 93' Paseo didn't have a VF2 connector, which means I don't get the serial communications...
Old 07-29-2011, 07:26 PM   #4 (permalink)
View earthquake's Photo Gallery
It seems your first error was using a Cat5 cable. Data to a Ethernet or TokenRing connection with Cat5 would not provide serial connectivity. Try using a 9-pin serial adaptor. It is the same as the old (I mean really old) serial modem connections. These were external modems, not the RJ-11 connection you have in your house for a phone line.
earthquake is offline   Reply With Quote
Old 07-30-2011, 07:54 AM   #5 (permalink)
Thanks but, no this Paseo doesn't have the newer port, just the old style diagnostic block.
I was just splicing the cable. No RJ-45 or BNC stuff. Cat 5e cable is good enough from 300 baud modem headset coupler to gigabit ethernet.
