97 Tercel where is the Downsteam Oxygen Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2010, 09:32 AM   #1 (permalink)
View Princenahum's Photo Gallery
USA 97 Tercel where is the Downsteam Oxygen Sensor
Hi everyone I need help replacing my downstream oxygen sensor. I found the downstream oxygen sensor but the wire travels up through a tank. I found this picture online Replaced my downstream o2 sensor with a simulator (many pics)
3rd from the top it shows where the oxygen sensor is on a 97 Avalon.
I was wondering if I had to do the same to access and replace my sensor.
Thank you
Princenahum is offline   Reply With Quote
Old 06-14-2010, 06:30 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Instead of looking at pictures online go pop your hood. Look down by radiator and you'll see a spark plug looking thing at the exhaust manifold, that is the upstream sensor. Now look under middle of car and you'll see a cat. converter under the seat area. Near that you'll see another plug thing and that's the downstream sensor.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
The Following User Says Thank You to Tercel GTS For This Useful Post:
Princenahum (06-15-2010)
Old 06-15-2010, 08:33 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Thank you
Jack up car and support with jack stands. Find sensor as per TercelGTS instructions. Cut wire and unscrew old sensor. Remove carpeting from passenger side footwell to find sensor connector. Remove and replace.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
The Following User Says Thank You to 96paseo For This Useful Post:
Old 06-15-2010, 08:38 PM   #4 (permalink)
Thank you
Thank you for you help the O2 sensor.
