manifold collector bolts/nuts keep coming loose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2010, 02:33 PM   #1 (permalink)
View m_wnzl's Photo Gallery
I have a '92 Paseo, actually have two, 1 automatic for the wife and a 5 speed for myself. My problem is I have had to replace the exhaust manifold collector gasket at least 5 times and need to do it again because the bolts/nuts keep loosening. I'm glad its an easy job but it sure is annoying, especially since the other car never has that problem. Help?
m_wnzl is offline   Reply With Quote
Old 06-12-2010, 04:40 PM   #2 (permalink)
SR20DETT's Avatar
View SR20DETT's Photo Gallery
You need to use jamb nuts otherwise they will always come loose. If you look at the original nuts they have a small shoulder on them that's crushed. That's to stop them from coming loose. If you just have regular nuts then put another one on and lock them against each other. Or get the right ones from the dealer.
SR20DETT is offline   Reply With Quote
The Following User Says Thank You to SR20DETT For This Useful Post:
m_wnzl (06-14-2010)
Old 06-12-2010, 05:17 PM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $954815
iTrader Score: 16 reviews
Try putting some Loctite thread compound on the threads before putting the nuts back on. They should hold on firmly after that. Also, it always pays to re-tighten the nuts once the car has reached normal operating temperature.
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
m_wnzl (06-14-2010)
Old 06-13-2010, 10:47 AM   #4 (permalink)
i tied the red loctite this last time, lasted maybe a week longer than normal. as for the jamb nuts? as in door jam? and are these a dealer item too?
Old 06-13-2010, 05:16 PM   #5 (permalink)
'95 Tercel DX
silverhawk's Avatar
View silverhawk's Photo Gallery
also make sure you're using the metal 2 layer gasket, the other kind will keep blowing out on you.
~mike
silverhawk is offline   Reply With Quote
Old 06-14-2010, 07:56 AM   #6 (permalink)
im not having a problem with the head to manifold gasket, its the manifold exhaust collector gasket that im dealing with. I dont know why I didnt think about double nutting it,but i like the idea, and using the jamb nut too.. thanks!!
