adjusting valves? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2010, 02:46 PM   #1 (permalink)
View m_wnzl's Photo Gallery
adjusting valves?
'92 Paseo 1.5 liter.. do the valves need to be adjusted periodically and if so, is there a spec/procedure reference I can use? Also how do I know if I have a 3e? or 5e?
m_wnzl is offline   Reply With Quote
Old 06-12-2010, 06:18 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
All Pseo came with 5efe and only way to adjust valves is to reshim them. Unless you've replaced the cam or had the head rebuilt this isn't needed. If they are making noise you may try marvel mystery oil.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-13-2010, 10:43 AM   #3 (permalink)
ok well that eliminates that idea. i was kinda hoping that somehow one of the exhaust valves got out of adjustment and isnt seating completely. as i have intermittent.. more so than not, but loss of compression in #4.
btw i love this site
Old 06-13-2010, 05:24 PM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Tercel GTS has mentioned before about the potential for sticking piston rings. This may be the root of your problem. Do you run synthetic oil?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 06-14-2010, 06:24 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Also I hate to bring bad news but keep in mind my Paseo project is on hold due to a worn block. My cylinder closest to belts (#1) has over .030" wear at one end on one side. 204,000 miles and it's a 91-92.
It really seems to me that 5e was a new design for that year and the blocks didn't get seasoned long enough. I haven't heard problems from 93 or 94 Paseo but 91-92 and 92 catch hell.
*for those wondering there was an early 92 Paseo that is often called a 91 or 91-92 as the whole car body and all are slightly different from the others
雄のハヤブサ
Old 06-14-2010, 07:40 AM   #6 (permalink)
i got it last year with about 180k on it and have already put about 30k since getting it. I have been using synthetic since I have had it. I tried the seafoam thing filling the cylinders and letting it soak a couple weekends ago and didnt notice any difference, and the only thing that seems to help a little is using Lucas Oil's gas additive.
