Tercel From Hell Update - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2010, 07:37 PM   #1 (permalink)
workman3886's Avatar
View workman3886's Photo Gallery
Well guys, a lot of you have been with me along the long road with my 92 Tercel...
As most of you know I have had some major problems, and some minor ones to...
As much as I love my Tercel, I have sunk more money into her, then any other project in my life... and she still doesn't run.
I have been debating what to do for some time now, to keep going and see how much money I will invest, or cut my loses before they become insanely deep... I am still wanting to get her running, but not knowing what's wrong, no check engine light, and no codes makes it that much worse...
I have been trying to do everything from the ground up with this car myself for pride more then anything, to say a thousand men have told me how to do it... but I did it. It really is a feeling like no other..
I have been working more then ever and the fact I have a company truck makes it easier to continue my project. Mostly I know my wife and my friends are getting fed up with me talking about my baby and not getting anywhere.
So today I have to make a decision, and I know I couldn't have a better group of guys behind me to help me out, so will she run... I hope
I may be bringing her somewhere soon for a group of people with better tools and more knowledge, although I wanted to get her running...
I am also having the hardest time with my ecu... it doesn't exist on the internet.. LOL, not for sale anyway... model number 89661-10110, I have looked none stop..
Gents, you have done more for me then anyone in my life... I need to take the next step
Ryan Workman
workman3886 is offline   Reply With Quote
Old 06-14-2010, 09:12 PM   #2 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
No luck from Tweak???
Glad to hear you're not giving up on it. Keep us updated.
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
Old 06-15-2010, 08:44 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Yikes. Seems like this one really put you through the ringer. Where did you last leave off as far as testing goes? Give me a little food for thought and I'll throw as many ideas as I can conjure up. Is it a no fuel or no spark condition? Or both?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 06-15-2010, 09:39 PM   #4 (permalink)
Well yeah Tweak did his part, he added the plug and returned the harness faster then I could blink, in all fairness, it stopped running before hand.
Well from what I can tell I have no spark, I seem to be getting fuel just fine, no spark, I did have a check engine light that is now gone, which makes me think the ecu, but I cannot find a exact replacement for it, I bought a ep91 3 plug Ecu, that didnt work.
I was told by my brother in law, who doesn't know imports as well as domestics that the sensor under the cap and rotor is what send the signal to the ignitor, then to the coil, then to the cap, honestly I don't know LOL...
I am open to ANY INPUT right now!
Old 06-15-2010, 09:43 PM   #5 (permalink)
BLARRGH!!!!
Madcat's Avatar
That does make sense about the dizzy.
Are you getting spark at all or is it just not sparking when it should?
Jim
Old 06-15-2010, 10:00 PM   #6 (permalink)
... It still runs...
View bkftl's Photo Gallery
check out car-part.com to find ur ECU, search by location
most junkyards will ship it to you if u pay a bit extra! call em up
goodluck dude
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 06-15-2010, 10:26 PM   #7 (permalink)
BLARRGH!!!!
Madcat's Avatar
Unless he gets extremely lucky that won't work.
He has the 4E-FTE. Never officialy imported to the U.S. by Toyota.
Jim
Old 06-15-2010, 10:29 PM   #8 (permalink)
Certifiably Insane
96paseo's Avatar
Ok. Was reading through your previous thread. Looks like you put in a new ignition coil and ignitor. Did you test the pickup coil? How did your old ignition coil test out? Did it match the new coil or was it bad? I read the thread on TO. Did the light bulb trick work? Are the rotor button and distributor cap intact? No cracks? Just going over the simple stuff first.
Old 06-24-2010, 06:23 PM   #9 (permalink)
View I am me's Photo Gallery
Well I have really no experience with cars but I read something about thermal expansion in the aluminum head so when you take the spark plug out and the head was hot the head might not go back to it's original position. I read that you took the spark plug while the engine was running, I don't know if you just pull the cable out or the spark plug.
Don't know if this is any help but I try to help.
I am me is offline   Reply With Quote
