Sorry I had previously deleted what I wrote.
So my turbo down pipe has broken the mounts a few times, and I keep needing to fix the down pipe or the turbo brackets. As it turns out my engine mounts are all shot - all 3 of them. My engine shakes around like a wild animal and snaps off turbo brackets!
I heard from a friend about 2 days ago that you could use Silicone, Glue or Polyurethane filler and fill up the round motor mounts to make them entirely solid so they are stiff, so the engine cannot fly around back and forth and damage the exhaust system or snap the turbo header.
Being sick of the engine rocking back and forth and not wanting to spend $70 a piece for new mounts, I ordered some $33 Urethane from McMaster-Carr.com per the recommendation of this random Hond* website I found
http://www.d-series.org/forums/diy-f...ne-mounts.html
I ordered the 60A Urethane and I am going to fill all 3 motor mounts so they are solid. This will prevent my engine from rocking about 1" back and forth as it does now, which should prevent my exhaust brackets from literally ripping off!
I have never used solid motor mounts, but the 60A hardness Urethane is supposed to be relatively flexible so the vibration is somewhat bearable. Anyone have any input on this? Is this a good idea?
http://www.ritalie.com/tercel/
