Engine rebuilders - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2010, 11:59 AM   #1 (permalink)
... It still runs...
View bkftl's Photo Gallery
Engine rebuilders
Can anyone recommed a long or short block engine rebuild service? How do i find one? I have been looking and looking and i cannot seem to find anything worthwhile. I have read some posts like turbo tercel where some one shipped the engine to get it inspected and rebuild at least partualy..?
Anyone know where one can purchase a rebuild 3ee engine cheaper then ebay? On ebay Long block is like 1000$ Ebay sellers have to get it from somewhere?
Thanks again for your replies!
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 06-18-2010, 07:56 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Most any parts store cn order a rebuilt engine or any machine shop can rebuild for you.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
The Following User Says Thank You to Tercel GTS For This Useful Post:
bkftl (06-21-2010)
Old 06-21-2010, 02:53 PM   #3 (permalink)
Thanks dude, Im just getting bullcrap quotes from "Engine rebuilders" there like 4000 for engine rebuild if they take it off, and 3000 or so if I bring the engine to them...
On autozone and ebay the rebuild engine is like 1000-1500$ which is still expensive, considering i have a fully working engine, exept its the rings are leaking...
I just need some one who can diagnose any problems, measure the cylinders for warpage, and possibly re-drill the holes. Maybe also rebuild cam?
I tried calling a few Machine shops but they say they can do it but there "NOT specialized in Engine rebuilds"
Would it make more sense to buy a rebuild engine and sell mine? How much is a used 3EE worth? I havent seen any on ebay so far...
Old 06-21-2010, 06:03 PM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Search the web for toyota rebuilt engines. There are companies out there that will take the old motor for a core. They aren't local unfortunately, but the shipping cost far outweighs getting ripped off. I mean like $4k, are they serious? You build a 5E and turbo it for about that much dough. Whoever you talked to, they're crazy. Just tryin' to your wallet.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
The Following User Says Thank You to 96paseo For This Useful Post:
bkftl (06-21-2010)
Old 06-21-2010, 06:46 PM   #5 (permalink)
heartdisease's Avatar
Gameroom cash: $117570
View heartdisease's Photo Gallery
Here is one--- http://www.promarengine.com/
Their was one mentioned on here that was very reasonable but I can't remember the name
heartdisease is offline   Reply With Quote
The Following User Says Thank You to heartdisease For This Useful Post:
bkftl (06-21-2010)
Old 06-21-2010, 07:49 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Just buy a used engine like I'm about to do. The 5efte was just getting too expensive. I can buy a 4efte running for less than the pistons and bearings.
雄のハヤブサ
bkftl (06-21-2010)
Old 06-21-2010, 10:37 PM   #7 (permalink)
Thanks guys, will check it out
Old 06-22-2010, 07:58 AM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Look up Tiger JDM. They have a 5efe for under $700 shipped. They also have a 4efte without ecu or harness for 650.
雄のハヤブサ
bkftl (06-23-2010)
Old 10-31-2010, 10:36 AM   #9 (permalink)
View gojrracing's Photo Gallery
Hi Tercel GTS. Yeah, that's absolutely true.
gojrracing is offline   Reply With Quote
Old 11-03-2010, 12:18 AM   #10 (permalink)
View playtimeover's Photo Gallery
Hi Tercel GTS. But you can do it on your own way if you know how to do it., right?
playtimeover is offline   Reply With Quote
Old 11-03-2010, 12:25 PM   #11 (permalink)
rdyzz's Avatar
Gameroom cash: $137800
View rdyzz's Photo Gallery
when i was planning on replacing my 5efe i did some research and asked alot of questions. the reason was due to a reman'ed engine costing only a little more then a used salvaged engine. 1,000-1,500reman vs 800-1,000 used w/shipping. mind you a reman'ed engine comes with a gasket set, whereas a salavged engine you might need to replace some of the seals.
i ended up going with a salvaged engine, spent about $400 extra on parts like seals, clutch, water pump, t-belt and idler pulleys. i talked to some of the toyota guys that i work with about reman'ed engines and alot of them say even engines that come from jespers have had to be pulled out and undergo warranty. the techs told me they have never had a problem with used/salvaged engines. i also read the same thing. so i figured toyota built it right the 1st time. theres a reason why a toyota built factory engine can run up to or more that 350,000miles. most rebuilt engines seem to last 50-80,000 miles.
if your engine is running still my not just do the work yourself. just take the head off and check all the torerence of the bearings while your at it and replace all the parts that need to be replaced. it might cost more it might cost less then a rebuilt engine, depends which corners you cut and how resourceful you are.
"driving safe doesn't mean driving slow"
91' mr2 with 3rd gen 3sge - SOLD
91' mr2 turbo - SOLD
96'paseo 40mpg DD!!!!!
90' corolla gts smallport engine FS... "levin front conversion" "current project" - BEAMS 3sge in the works
rdyzz is offline   Reply With Quote
