96 Tercel idle speed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2010, 10:49 AM   #1 (permalink)
View Ru4wheel?'s Photo Gallery
What is the correct idle speed? I also have a P0171 code this morning. Too lean at cylinder one. Thanks.
notagain
Ru4wheel? is offline   Reply With Quote
Old 06-21-2010, 05:17 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
750 RPM for a stick and 800 RPM for an automatic. IAC and teh ECU control the idle speed on the DIS 5E. As for the code, check for vacuum leaks. Most importantly the large rubber hose going to the throttle body from the air box. It can crack over time.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 06-23-2010, 06:42 PM   #3 (permalink)
I broke down and sent it to the shop. $377 dollars and a new fuel pump fixed (?) the P0171 code. They said the fuel pressure was only 14psi and should be 40psi. Just picked it up today.
notagain
Old 06-23-2010, 10:49 PM   #4 (permalink)
... It still runs...
View bkftl's Photo Gallery
Might also be FUEL FILTER, i had to change mine. I saw a 93 tercel video it idles at around 550 rpm. So it realy varries, it can even change if u put different type of oil. It just has to sound right, no loud idling, no shakes, and consistent offcourse.
Anyways listen to paseo hes da man
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
