Name that part... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2010, 05:26 PM   #1 (permalink)
View Ru4wheel?'s Photo Gallery
Name that part...
On the back of the throddle body, towards the fire wall, is a black part held in place, top and bottom, with two phillip head screws. And it has a elec connector. What part is that? (96' 5EFE engine.)
Also on the throddle body, below the air inlet tube is a gray plastic part with a built in soleniod. It is held in place by two phillip head screws side by side. What is that? Thanks....
notagain
Ru4wheel? is offline   Reply With Quote
Old 06-19-2010, 05:54 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Question 1. what is a throttle position sensor.
Question 2. what is an idle air control.
Not 100% but should be right.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-19-2010, 07:39 PM   #3 (permalink)
I am looking for the MAF or MAP sensors. I want to clean it (or them whichever the case may be). But thanks for the answers! Do you know if the 96' 5EFE has a MAP or MAF?
notagain
Old 06-19-2010, 11:37 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
It has a MAP. You don't clean them. It's on the firewall near the master cylinder. It's a small black part with a vacuum line and an electrical plug.
雄のハヤブサ
Old 06-20-2010, 05:42 AM   #5 (permalink)
Wow. That little thing? I looked on Rockauto ($47!) and I know where that part is. I was at a junk yard yesterday and grabbed a couple things off an engine. A spare EGR and that MAP thing amoung others. The loose parts cost me over 40 dollars, but I guess I did OK. Today I'll install them and hope that helps. Thanks.
notagain
Old 06-20-2010, 07:14 AM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Very welcome, let us know how it turns out.
雄のハヤブサ
