4 speed Shift Points? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2010, 08:44 AM   #1 (permalink)
... It still runs...
View bkftl's Photo Gallery
Talking 4 speed Shift Points?
Hopefully gonna get tercel on actual road today, not just driveway. I got it registered.
I was wondering if anyone knows the proper shift points? At what speed do i shift it? Its usualy in the owners manual, i dont have one
94 Tercel 4 speed manual
THanks!
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 06-25-2010, 12:02 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Don't listen to the manual, just shift however you want. Shifting at lower RPM's will help your gas mileage a bit but these cars get great MPG already so its not a big concern. I usually shift between 3-4k but its really your preference.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 06-25-2010, 12:54 PM   #3 (permalink)
Tinkering Addict
noahthefrog's Avatar
Gameroom cash: $101100
View noahthefrog's Photo Gallery
All you have to concern yourself with is not over-revving in any gear (you'll know when you do, it's loud!). Even that is hard to do with the torque & HP curve on these motors topping out about 1000RPM before the redline. If you are aiming for efficiency, drive in whatever gear requires you to press down the gas pedal the least amount and still makes the car go faster.
Replacing my car... One part at a time
'89 Tercel EZ - 4 speed manual - Weber 32/36 Carburetor - 175K miles
3E Weber swap guide: http://www.toyotanation.com/forum/sh...d.php?t=346767
noahthefrog is offline   Reply With Quote
Old 06-28-2010, 11:18 AM   #4 (permalink)
Drives 1 loud yota!!!
View steveokinevo's Photo Gallery
i think he might be askin when because he has no RPM gauge...... i know i dont......
steveokinevo is offline   Reply With Quote
The Following User Says Thank You to steveokinevo For This Useful Post:
bkftl (06-28-2010)
Old 06-28-2010, 12:00 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Been a long time but seems like it was 30-45-65-110
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
The Following User Says Thank You to Tercel GTS For This Useful Post:
bkftl (06-28-2010)
Old 06-28-2010, 10:24 PM   #6 (permalink)
Thanks guys, working well so far
but the CV is busted it rattles when accelerating and decelerating with engine
Yeah it would be eazier to drive if i had a RPM tachometer. But then again, in agresssive city driving, i need to keep my eyes on the road, people dont respect small cars
Thanks again!
