Fuel regulator question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2010, 07:44 PM   #1 (permalink)
View Ru4wheel?'s Photo Gallery
At the end of the fuel regulator is a small hose that goes down and plugs into the #1 (or so it appears to) cylinder in-take manifold. Where is that fuel going? I unpluged the hose and fuel was coming out of the end of the regulator. I guess that's normal. I hope the overflow of fuel isn't going into #1 cylinder. What's happening to it? Thanks,
notagain
Ru4wheel? is offline   Reply With Quote
Old 06-26-2010, 09:53 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Thats not good. Sounds like the diaphragm inside the regulator ruptured. Seems like the shop forgot to test it after changing your fuel pump. The regulator can be had on Ebay for relatively cheap. Make sure it comes with a new o-ring. Do not attempt to re-use the old o-ring. It will leak.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 06-27-2010, 04:39 PM   #3 (permalink)
OK, thanks. I'll try to find an o-ring for the unit I just bought at the junk yard today (for $10). Thanks for your help!
notagain
Old 06-27-2010, 05:18 PM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Your local parts store should have a box of different sized o-rings. Just bring the unit with you and size it up. Make sure it fits snug. Be careful to properly seat the regulator when re-installing. Fully seat it with your hands, then put the bolts in. Don't use the bolts to draw it in.
