Popping sound resolved. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2010, 12:47 AM   #1 (permalink)
View turtle93's Photo Gallery
The popping turned out to be the balancer collar on the passenger side half shart. It appears to be set in rubber, but mine tore loose and was freely rattling around on the shaft. Has anyone had this happen before? Unfortunately, it looks like the only fix is to replace the shaft, unless I can silicone it back in place.
turtle93 is offline   Reply With Quote
Old 06-28-2010, 02:07 AM   #2 (permalink)
Tercel
3ee4banger's Avatar
View 3ee4banger's Photo Gallery
The same thing happened to me got it cut off the axle and that was my fix the only thing cutting it off did is stop my steering wheel from shacking on the highway
93 Tercel 5 speed
3ee4banger is offline   Reply With Quote
Old 06-29-2010, 11:17 AM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Doubt that silicone is gonna hold it. Mine is pretty well cracked and moves around a good bit but hasn't broken yet. Good idea to replace the shaft but check the boots on both LF and RF shafts. They may not be far behind and you may be in need of a pair of new shafts. If the CV joints are in good shape, you can go the rebuild route. Its messy and a PITA but cheaper.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
