Tire Sizes... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2010, 09:54 PM   #1 (permalink)
View lt1tyrell's Photo Gallery
Tire Sizes...
I am getting ready to replace the tires on my 91 tercel. From the information I can find the original tires should be 155/80/13. My car has 185/70/13's on it right now. So I think they are about an inch taller than factory. Should I go back to the factory size or stay with whats on it? It is a 3 spd auto so with out OD it is a little buzzy on the highway and I guess it would rev a little higher if I went back to the original size. Also, anybody know a good cheap brand of 13'' tires? Thanks.
lt1tyrell is offline   Reply With Quote
Old 06-28-2010, 10:12 PM   #2 (permalink)
... It still runs...
View bkftl's Photo Gallery
yeah i think they are called R13 tires, fairly cheap around 30$ a peice. Check at ur local tireshops, they usualy have some kind of a deal like 4 tires for price of 3 or discount for buying 4 at once. check it out.
Im not realy sure what numbers mean also where did u find these numbers?
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 06-28-2010, 10:25 PM   #3 (permalink)
View turtle10's Photo Gallery
Here is an easy to use tire calculator:
http://www.discounttire.com/dtcs/infoTireMath.dos
You should be able to use 175/70-13 tires with no problems. They are only .11 inches shorter. You find this out by entering the tire measurements in each side of the calculator and click "Specs/Compare".
175 is the width in mm.
70 is the aspect ratio for the side wall height. 70% of 175mm.
13 is the wheel diameter in inches.
You may need to check inside clearances near the struts/shocks because they are 20mm wider than stock.
-Michael
turtle10 is offline   Reply With Quote
Old 06-28-2010, 10:30 PM   #4 (permalink)
Tinkering Addict
noahthefrog's Avatar
Gameroom cash: $101100
View noahthefrog's Photo Gallery
The 185 in the size is the width of the tire and the 80 or 70 is the ratio of the width to the height if I remember correctly. I have 175-70-r13's on my '89 tercel and they seem to be a good fit. I don't recommend the 155 tires - the cornering is not very good with such a thin tire. If the 185's have been serving you well, then I would replace them with the same size. Wider tires give you better cornering.
Replacing my car... One part at a time
'89 Tercel EZ - 4 speed manual - Weber 32/36 Carburetor - 175K miles
3E Weber swap guide: http://www.toyotanation.com/forum/sh...d.php?t=346767
noahthefrog is offline   Reply With Quote
Old 06-30-2010, 09:13 PM   #5 (permalink)
nighthawk8's Avatar
View nighthawk8's Photo Gallery
Ya i wouldn't recomend the 155 80 r13. depending where you are in canada, you can get the motomaster tires from canadian tire. The 155 80 r13's are like 34 bucks each
nighthawk8 is offline   Reply With Quote
Old 07-01-2010, 08:50 AM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
When I had stock wheels I used goodyear viva tires from walmart.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
